So that’s a “yes” then? If you fail to transmit the digital data that is still digital data transmission. Thx, got it.Because you continue to conflate data transmission (defined by serial, parallel, synchronous, and asynchronous data) with the actual data stream itself.
The data protocol defines the connection cable, the signal it transfers and the error correction/detection codes. Good luck trying to hammer a USB cable into an Ethernet port. Maybe an audiophile USB cable would work?No, I'm not failing, it is you who are conflating the connection cable with the protocols of the system
The inclusion of error correction and/or detection code is a requirement of the USB spec and always has been as far as I’m aware. Version 2.0 for example upgraded to 5bit CRC for all start of frame packets and USB 3.1 to 32bit CRC. Even the consumer S/PDif protocol incorporates CRC (and parity bits).USB has modes that don't use ECC.
G
