Differential output and question
Jun 23, 2008 at 3:30 PM Thread Starter Post #1 of 2
Apocalypsee
What are the purpose/advantages of having differential outputs?
My question is I currently run my X-Fi without opamp, is it OK just to solder the + (non inverting) part without the - (inverted phase) to the output?
Jun 24, 2008 at 1:30 AM Post #2 of 2
TzeYang
Depending on what the opamp actually does
normally you cant just remove them because they either work as:
1) IV Converter
2) Line out amplifier.
