YakAttack
- Mar 24, 2011
For the longest I've used Nero to record output my mixes, using 48000 - 32 bit as the default output. However, I've always just selected Stereo. However, in an attempt to raise the quality of the mix, I was thinking of doing 8 channel. When I hear it (through my Sennheiser HD 25's), the overall volume seems lower, though (and I may be ideally be hearing things that aren't there), it seems the soundstage is more open, and the music is a little more distinct.
From what I read, 8 channel allows all channels to be used in speakers, but I would presume that's if you have more than a couple of speakers. What I would like to know is if I record in 8 Channel, and put it in my car, or a stereo with more than 2 speakers, would there be a noticeable difference in quality?
PS: Just noticed that when saving in 8 Channel mode, the size of the file is a lot bigger (guess due to the separation of channels), but it always stops around 46 minutes (whereas my mixes usually are an hour to hour and 5 minutes). Is this normal in Nero?
Thank you
Thank you
