Headphonefred
- Feb 16, 2012
Hey guys, title says it all, i hear that record players etc have superior sound to digital players eg ipod or stereo system. Is this true, and why? Comments much appreciated
Where the analog > digital thing comes from is two things:
- Nostalgia and the love of tangibility
- Mastering, since many old vinyl records have better mastering than modern CDs. This is not because of some inherent disadvantage of digital
This is the major key for something to sound good! MASTERING!
The reason most vinyl sounds better is because vinyl has a threshold as to how loud a signal can be so mastering is usually very conservative in the dynamic area. However, there are some vinyl records which have been mastered using brickwalled digital tapes/CD's like "Californication".
All things being equal, a regular CD can sound just as good as vinyl if mastered correctly. Mastering guru Steve Hoffman once said that he sync'd up three masters...the master tape, the master vinyl lacquer and the master CD. He said that listening very closely, under ideal conditions, there was no difference between the master tape and the master vinyl lacquer. The only difference between the master tape and the CD was a slight loss of ambiance.
Considering the inherent playback problems of vinyl, all things being equal, I'll take a slight loss of ambiance any day of the week over clicks, pops, warps and vinyl gremlins.
all sound can be expressed as a complex series of sine waves. So you only need an approximation, then you can just connect the dots.
These are very good posts.
I'll just interject, in theory vinyl has higher fidelity than 16/44.1 CD quality, though I'd like to think 24/48 blu-ray audio quality really has 'surpassed' vinyl.
Originally Posted by Head Injury /img/forum/go_quote.gif
Vinyl has a lower dynamic range than 16 bit digital audio. I think it's usually around ~80 dB, which is about 13 bits.
In theory, vinyl can record higher frequencies than 44.1 kHz. In reality, we can't hear those frequencies, a typical microphone doesn't pick up anything meaningful above those frequencies, and instruments don't make much sound above those frequencies. Also in reality, the grooves must be very precise to record those frequencies. You won't get "high fidelity" for very long because the needle is going to wear the fine details out.
24/192 is closer to the original analog waveform.
Could you tell me
- The source of this?
- What the axes represent?
- What is being measured, the digital or analog waveform?
- With what equipment?
In the above graph, note that there are straight lines connecting the dots (samples presumably), visible on the 16/44.1. That's not how the D/A would actually work.
Could you tell me
I drew it in mspaint. =]
Here is the link - http://www.cicsmemoryplayer.com/index.php?n=CMP.02Upsampling
Quote:In the above graph, note that there are straight lines connecting the dots (samples presumably), visible on the 16/44.1. That's not how the D/A would actually work.
I think the lines will still be straight, if the D/A doesn't alter them.
Audio music starts off as analog (wave) audio, vinyl is an analog (wave) recording, we hear in analog (wave).
Digital (zero & ones) is a cheaper and more reliable way of storing music, then analog.
I'm guessing recording studio have very expensive ADCs (Analog to Digital Converters) for storing audio in a digital format.
As the audio we listen to is stored in a digital format, we need a DAC (Digital to Analog Converter) to hear the audio because we hear humans hear in analog.
Every time the audio is converted from analog to digital to analog, it going to lose some of the sound quality.
Like a copy of a copy of a copy.
Now if you have a sound studio with ADCs and DACs worth thousands of dollars, you are only going to lose a very very small amount of quality in the audio.
Your digital home audio player or portable audio player uses a DAC that costs maybe a dollar or two.
In the past, audio was recorded on the analog (wave) tape, records are/were analog copies of a analog signal, your record player does not need to use a DAC for converting.
I'm not an audio engineer and I'm sure there are factors that I have missed, but it might help answer in some way your question.
