ACDOAN
- Jan 16, 2011
Any thought ?
- Frequency response: 20 Hz - 20 KHz (+1 dBu)
- Signal-to-Noise Ratio: > 75 dB
- THD: < 0.01%
- Bluetooth Version: 2.1 + Enhanced Data Rate (EDR)
- Maximum Receiver Power: Class 2, 4 dBm
- Receiver Frequency: 2.4 GHz - 2.480 GHz
- Receiver Range: Up to 82 ft. / 25 m
- Receiver Sensitivity: -80 dBm @ 0.1% BER
- Supported Codec: SBC, MP3, AAC, aptX
- Supported Profiles: AVCTP 1.0, AVRCP 1.0, GAVDP 1.2, AVDTP 1.0, A2DP 1.2, Hands-Free Profile (HFP) 1.5, Headset Profile (HSP) 1.1
- Analog Output:
- Balanced (XLR): +4 dBu (+1 dB)
- Unbalanced (1/4" / 6.35mm): -2 dBu (+1 dB)
- Operation Temperature: 41-95 F / 5-35 C
- Power Adapter: 5 V DC, 3 A, center-positive
- Input Voltage: 100-240 V AC, 50/60 Hz
- Dimensions: 5.8" x 4.6" x 1.8" (149 x 117 x 45 mm)
- Weight: 1.3 lbs. (0.6kg)
- THD: < 0.01%
- Analog Output:
