ezzieyguywuf
- Aug 20, 2005
xI'm freaking out guys. I noticed today that one of the cups on my Denon D2000s seemed to be coming off so I took the ear pad off to get a closer look. Turns out theres 4 screws that hold the whole driver-cup assembly to the swivel. Only two of these screws were present and of those two only one was snug. The other three had stripped threads. I pulled off the other ear cup to check if maybe it was standard to have only two screws. Not the case. It had four screws and they were all snug.
These cans are not stock. They have wooden cups and an aftermarket cable. I did not perform these mods. I bought these cans from a forum member (just contacted him to see if maybe he didn't have the same problems) who I'm pretty sure had the mods performed by someone else.
I am very very sad right now. I have not been at all agressive with these cans, and all I want is to use them again. There is nothing wrong with the drivers (as far as my ears can tell) but I'm hesitant to continue listening to them with essentially one screw holding on the whole left cup-driver assembly. I could really use some help here. Is this a common problem? Is it easy to fix?
Update: Pictures!
Heres where my freak-out started
A closer look didn't help. Decided to pull it apart to further investigate
You can imagine my surprise when I saw that there were only two screws holding this sucker in place. When I went to strategically move one of those two screws so that they would be diagonal from each other, I was dissapointed to find that the threads were stripped out!
This is where the screws go into. As you can see, this is a plastic fixture. The threads in three out of four of these was bad. When I screw the screws in with the driver out like this, they go in fine, which leads me to believe that there are threads further down in the bore, but that they are stripped out closer to the top. This led to my theory...
As you can see, I had to pull the cable out some in order to get this thing in a position to work with, i.e. if I wanted to put new cups in, then I would have to pull the cable out some to get to it. This last image also shows the protrusions that go into the bosses on the driver-cup assembly. My theory is that when the last modification was made, maybe the cable got in the way of the protrusions sitting in the bosses flushly. This would mean that even though the screws might snug up, they would only have a few threads engaged. Since the whol assembly, according to my theory, is only being held in by a few threads, this means that it was only a matter of time before some minor bump yanked these threads out.
Let me know what you guys think of my theory!!!
Update: Pictures!
