tomjonesrocks
- Jun 15, 2006
So I'm an old-timer that kind of found a sound that suited and was good to go. This sound/product was the Denon AH-D2000. Unsure anyone still has this model but throwing a hail-mary in case.
The problem is they fall apart all the time and are hard to put back together. They have a very small bolt in a *very* tight area that gets loose all the time. I usually use 2 tiny screwdrivers to try to screw them back together but it's difficult and never lasts very long.
Has anyone every found the tool for this bolt? If so would love to know it -
...Edit - doesn't seem like I'm having any luck posting images. Here's the link:
https://imgur.com/a/gge54Vd
