Originally posted by cadjack
Now you're getting to the heart of the matter, CrawlingEye. Music Fanatic's post had me thinking in measureable terms, not perception of sound and the way the player's setup affects it..Nobody listens to sine waves dangit.
Back in the day, the Jazz/Precison hybrid was the holy grail for most bass players. The best tone to my ears was from an early Rick 4001 using a blackface Bassman for a preamp, Phase Linear 400 for power, and old 15" EV SRO whitebacks in homemade cabs. The equation doesn't add up, but it beat the '69 Fenders and even Tobias prototype #3 for tone. Different amps, natch.
The player, instrument, amp, and personal perception of perfection can't be measured in numbers or words. I'm just a roadhouse rocker (and I'm not trying to come off as snobby at all) the sound starts with the player's thoughts and seldom ends up as he intended. Magic or mush seems to be in the ear of the beholder, I'd rather hear it the way it was played.
-Jack |
Agreed. But having heard many amps, I must say that not all sounds are for all musicians, and the obvious result is different sounding bassists with preferences for certain amplifies, cables, basses, strings and cabinets. One look at talkbass.com will confirm this for anyone.
With this said, I personally have been through many painstaking years of trying to find my 'ideal' sound. I've found 2 rigs which I've persued which come close to it. One of them being a Peavey BAM combo, which has amp modeling circuitry and allows you to mix and match certain classic amplifier and cabinet combinations to your taste, then use EQ's which are modeled to act as they would on the original amp. I think the best sound I've heard from this is the 1x15 fliptop cab model (I assume an old Ampeg fliptop tube amp model) and Peavey T-Max amp model. It struck a good smooth medium for me, with my Music Man Sterling.
Another that struck me as being rather good sounding, even better IMO, was the GK 800RB with a Bag End S15X-D plugged in. Running at 200w, I think I'd have to push it very hard at band practices, so I'm thinking of buying a second S15X-D once I start on my new rig.
I've also tested multiple sets of strings. From GHS groundwound's to Rotosound Swing 66's to DR Lo-Riders and Hi-Beams to D'Addario Prisms. I've finally settled on the Prisms, they have good 'ping' in my opinion, which compliments the style of music I play (largely rock-based).
I hope this post gives many of you some insight of the research along with trial and error that some musicians go through to come up with 'their ideal sound' for things. I could easily go into all my past purchases and take up paragraphs worth, but instead, I just tried to go into a couple details. Not all basses sound the same and not all are intended to sound the same. An 'ideal headphone' may make things sound punchy to you, but this may not be all so accurate.
My personal ideal sound for my bass setup would not be to extend to 15Hz, as I don't even play a 5 string (which would be required to even get near there). 4 String basses (the industry standard) only go down to 41Hz, most cabinets are tuned to reach 35Hz or 40Hz, as this is all that is required to produce a fundamental for the Low E and all of its harmonic octaves. I don't mean this to sway anyone from a headphone that boasts "fs down to 9Hz" but I do mean it to show that the capability of 9Hz may go unused most all the time.
I hope this helps everyone understand things a bit clearer.
