Loftprojection
- May 26, 2005
I think if I was you one thing I would consider is the headphones you plan to use and keep for a while. If they are very efficient, like AudioTechnica or Grado, then the option of a DAC with headphone out is something interesting. However if you plan on changing headphones often then keeping your seperate amp is a must.
As far as the Arcam CD73, I'm not sure you will be happy. It is a nice CDP but I'm sure it is a sideway change versus your Minimax if not lower. I own the Arcam CD23T and that is a uge step above the CD73. If your budget allows going up to $800-900, there are some used CD23 on Audiogon, that would be a better improvement than a CD73.
For the DAC, the DAC-60 is certainly an interesting option since you can get it stock under $500 and when you have more money you send for the Sonicap upgrade. I've never heard any of the DACs your are looking at but I would bet the DAC-60 is way up there.
Have fun with your decision!
