I've actually tried to mod Sony Z600 (=V600) by swapping circuit from Philips HN100. HN100 was an OK-sounding phone but NC effect was minimum, so I thought if I put them in more isolating closed phone it would work better.
Here's the pic of HN100 inside the cup.
See the little mic on the cup? The little green board in the center carries no circuit, it's just a connection point.
I took the whole circuit (including mic and driver) from HN100 and literally shoved them into Z600. (made hole for mic, too)
Result? It actually ADDED ambient sound, so loud that it exceeded the level of "cancelling". Yes, it was noisier than passive isolation. I switched cables to see if I made wrong connection but that was not the case. Surely the added sound was amplified ambient noise, like sound of cars, TV, etc.
I think the circuit needs feedback loop to compensate the level of reverse phase sound, but obviously Philips' circuit didn't have it. In fact, HN100 doesn't have completely closed back, I think HN100 is mechanically balanced to match the level of incoming noise and reverse tone. Low cost, but won't perform well.
Here's the pic of PXC250, mic is located in the center of the driver.
If you turn on NC and gently cover the center of the driver with your palm or thumb, driver starts to beep. I think it's because of the feed back circuit.
Also, PXC250 has a small hole on the back of both cups. Don't know why.
Are these metal mesh grills mics?
No. If you cover these with your hand while NC is on, no matter how firm you press your hand, it doesn't change the sound. (Actually shuts down a bit of outside noise.) I believe mics are hidden inside the circuit.
I can't see it but I'm not ready to tear down seldom used $300 phone yet, so I'll leave it a big mystery.
Oh and use ER-4 beneath QC2? Maybe I'll try on my next flight(don't know when), but still you can't get rid of low freq noise transmitted from the seat to your skull. (bugs me when I try to sleep)
