pataburd
Tour,
Actually, the two potentiometers can come in very handy to really "fine tune" the balance. I avail myself often of this feature on the 337, always to satisfying effect. To be honest, I thought having two volume pots would be a pain, too, but my actual experience with the 337 has proven otherwise. I will say, though, that for the D2000 there is way too much gain in too short a twist--on a hair trigger--and therefore not much effective effective control. For the K501 the volume control works better.
Also, IMHE, the 337 does not sound "tubey" at all, rather quite balanced, extended and neutral. This is similar to the experience I had with the 336i (I think the 6AS7 power tube may be the key to such success.) In addition, the 337 offers the punch and dynamics of a good tube design. As an aside, in the past, I've owned Kora (all tube) power amps which I strongly preferred to some of the best SS amps, like the Plinius, where the Koras apparently "beat the Plinius at their own (SS) game." On the other hand, I've heard SS amps with a decidedly tubey presentation.
Again, God willing, I intend to a/b the 337 and the PH-12, stock, then, ideally, mod the PH-12 and re-a/b. Keep in mind that the V-Caps alone that I want to use in the Bada will cost close to $300.
Both the Bada and the Darkvoice are, IMHO, very satisfying amps each in their own, unique way. The sonics in the former are designed around the 6SN7, a tube which imparts tonal/harmonic richness and liquidity; in the latter, the 6SJ7 and 6AS7 successfully achieve very laudible neutrality, authority and detail. Given their "in-the-same-ballpark" MSRP, they make a great pair of amps to compare and comment upon--something I look very much forward to doing. : )
Tour, I'll endeavor to get the ahp fuse into the Bada, and get the Bada back up-and-running next week. : ) It's not going anywhere, believe me! : )
PAB
Originally Posted by tourmaline /img/forum/go_quote.gif One thing i don't like about the darkvoice is two potentiometers for left and right channel. You never get it right unless you use stepped pots in there or use one combined pot for left and right. The other one being total tube sound. I like the hybrids best. Looks nice though. enjoy the amp. |
Tour,
PAB
