Hi all,
I've recently started to notice issues with my Darkvoice 336SE while using my speakers with it. The right channel is producing a slightly lower volume than the right. What's also interesting is that the right channel doesn't seem to be producing any bass at all. Only mids and highs. This occurs when I'm plugged into the RCA outputs to my speakers.
I've isolated the problem to being the output plugs being the issue since swapping different tubes yield no different effects. I've also plugged my speaker through the front 1/4" connection and it does not have the same problem.
What are my options with fixing the RCA output?
