41Venom14
- Dec 22, 2016
Hello all audophiles,
I hope to reach into the pool of knowledge that is hidden away in Head-Fi.
I purchased a DarkVoice and have had it for about a month with no issues. I have been tube rolling and getting experience with different sounds.
However, today I dropped in some new tubes, fired her up, and sound was only coming out of the right channel.
I figured, okay bad tubes, annoying, so I switched back to tubes that I know WORK.
Still have the same issue.
I've read somewhere that possibly discharging the capacitors may be the option, but I do not know how to do that. I popped open the back, there was nothing in there that signified burned out or broken connections, I am very confused and worried.
At the moment the DarkVoice is being left unplugged from the wall in hopes to drain the capacitors. Any information or ideas would be appreciated.
Thank you all.
Thank you all.
