Thanks, Guys
This is the DAP I am getting:
https://www.pioneerelectronics.com/PUSA/Home/High-Resolution+Audio/XDP-30R-B
And thanks for the heads up. My Carver Preamp now does not have XLR's but I just freed up this Mcintosh and might try it:
http://img.aussieaudiomart.com/uplo...9-preamp-amazing-value-incl-phono-and-dac.jpg
https://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Home/XDP-30R_top_171221_web.pdf
You can connect a headphone amplifier or
D/A converter, for example, that has line
input. You will need a headphone plug
(commercially available) to connect to this
unit. Make sure you have the correct type
of headphone plug for the jack of the
device you are connecting.
Connecting a device
1. Connect the device to this unit through
the headphone jack.
2. Turn on the power of this unit, and select
"Line Out" in the home screen to turn
Line Out on. "Line Out" is displayed on
the status bar on the screen when this is
on.
0 When "Line Out" is on, output through
the headphone jack is at maximum
volume, so do not use headphones.
Adjust the volume on the connected
device.
∫ Balanced Output Select
Use when balanced headphones are to be connected.
"Balanced (default value)": Compared to the normal single-ended operation, you can get a
larger output and the high voltage is not grounded together with the small signal, so you can
anticipate a superior effect in the quality of the music. Because you get a larger output, you
can drive headphones with a higher impedance.
"ACG": The basic operating method is the same as Balanced (mode), but uses technology
to even more forcefully fix grounding standards, so you can enjoy a sound quality with
improved clarity and stability than Balanced (mode). Output volume is the same as the
regular single-ended operation, however.
0 This unit does not support simultaneous use of the balanced headphone jack and the
headphone jack. Using both jacks at the same time may result in damage.
∫ Line Out Mode
"On": Switch the headphone output to the line output mode to connect external equipment.
When "Line Out Mode" is on, output through the headphone jack is at maximum volume, so
do not use headphones. Adjust the volume on the connected device.
0 When turned on for European models, you can then select either "Fixed (default value)"
or "Variable". When "Variable" is selected, volume can be adjusted on this unit. If you
select "Fixed", adjust the volume on the connected external device.
"Off (default value)": Line output is not enabled
∫ Audio
Gain: You can select the headphone output level to suit your headphones.
Select "High (default value)", "Normal", or "Low".
0 Lower the volume first if you intend to select "High".
0 When connecting a pair of headphones for the first time, set to "Low" and change the
volume level gradually.
