Herandu
Banned: Shares IP addresses with DC Lee StanleyB1
- May 20, 2006
Every conversion process means using more components in the signal chain, which affects the sound. All unbalanced to balanced circuits I have come across use an opamp for the conversion. Most of those opamps are at the bottom of the pile in terms of performance. So is it worth it?
I don't use balanced, and don't have a noisy system or 100 meter cable runs to justify balanced. IMHO a short run balanced system is inferior to a short run unbalanced,brought about by the same circuit that converts unbalanced to balanced.
Originally Posted by datura647 /img/forum/go_quote.gif Isn't it true that a balanced source isn't necessary to get all the benefits from balanced drive? What I mean is some balanced headphone amps convert a non balanced input signal to a fully balanced output to the headphones |
