cloud13cherish
- Dec 27, 2014
Hi, I'd like to ask for some recommendation between DACMAGIC XS, Meridian explorer and Meridian explorer 2. I use B&W P7 as a headphone and need a DAC USB[ my first DAC/DAC USB]. Done with the researh, I found DACPORT/ Dragonfly v1.2/ DACMAGIC XS/ Meridian explorer 2 etc.
Now, I decided to choose between DACMAGIC XS and Meridian explorer2. I don't have strict budget but I want to make the right choice. I know both can do 24bit 192kHz but need to know which one has better[clear, warm, etc]. What I am curious is whether Meridian Explorer 2 is worth buying.(over DACMAGIC XS) Like is there a significant in there DAC processing making Meridian Explorer 2 more clear, bigger sound stage, etc . Or am I OK enough with the DACMAGIC XS. I did some goolging but it's hard to get informations about the comparison of these two.
