DAC with 4.4mm headphone and optical out?
Dec 12, 2022 at 4:18 PM Thread Starter Post #1 of 5
skycracksopen
I'm currently using a Cambridge DacMagic Plus with my PC. I use the headphone out most of the time, but also use the optical out when I want to play the audio through my stereo.
It's starting to wear out after about 8 years of use, so I'm looking for something similar, with additional 4.4mm balanced out for headphones.
So far, I can't find any devices that have both 4.4mm and optical outputs.
It's starting to look like I might need 2 separate devices, but I thought I'd check here first if anybody has any ideas.
Thanks!
Dec 12, 2022 at 4:53 PM Post #2 of 5
My receiver also has a S/PDIF digital connection. The kind that looks like an RCA connection.
Maybe I could use that in place of optical.
But can that signal go about 30 feet without much degradation? Probably not...
Dec 13, 2022 at 1:37 AM Post #3 of 5
Dec 13, 2022 at 7:49 AM Post #4 of 5
Get your self a good quality 75 Ohm cable. Simply try a RG6 cable.
As a DAC is a Digital to Analog Converter, DAC's with optical out are a bit rare.
A more common one is a pre-amp style DAC so digital inputs and both line out (RCA or XLR) and a headphone out.
However, it looks like Reebonz has landed your unicorn
