If I turn the amp up to 80% and send a very low level signal out from the chord mojo for example, degrade the signal?
Very possibly. Unfortunately there’s no simple answer to this question because it depends on a number of factors that aren’t usually obvious. As a general rule of thumb, the ideal digital output level is around 98%.
If I’ve understood what you’ve posted, a -33dB digital volume setting equates to roughly 6bits. In other words, this setting effectively turns a 16bit audio file into a 10bit audio file by removing about 6 of the least significant bits (LSBs). Then you are amplifying that 10bit file with an 80% setting on your amp, which in most/many cases will add more noise and distortion than say a 50% amp setting. In this scenario it is entirely possible (even probable) you could hear a loss of resolution, more noise or distortion. However, this exact scenario is unlikely, it’s likely your DAC is lowering the digital volume in a 24bit environment, Eg. It’s padding the 16bit file to 24bit by adding 8 bits set to zero. In this scenario, loosing 6 of the added 8 zeroed bits cannot have any effect. However, the amp’s high gain setting still could and there are other factors I haven’t mentioned which might.
In addition, on the other side of the coin, a very low setting on your amp can also have detrimental effects with some amps.
There are 3 ways to be sure of what’s going on and whether you’re loosing resolution and/or adding noise:
1. Measure the amp’s output with low digital volume and high amp gain vs high digital output and low amp gain. However, you’ll obviously need measuring equipment for this.
2. Compare the results of a null test for each of the two settings. However, you’ll need an ADC and some free software for this.
3. Do a blind/double blind test of the two settings. However, you’ll need someone to help and it will be difficult to setup this test so the results are reliable.
I know this isn’t a particularly helpful response but at least you have some idea of why there isn’t a simple answer to your question. I can provide advice if you want but it would be almost entirely a guess and the same would be true of anyone else, unless they had done one of the 3 options above with your specific models of DAC and amp.
G
