Hi!
I do not want to start another similar thread so I'll write my question here.
I was a happy owner of an ASUS Xonar D2X until I SLIed...
From that moment I had noise/buzzing/crackling like hell when I was gaming!(in teamspeak/skype etc) only the others could here those noises. Not me.
From what I found D2X was picking from mic input the noise from the gpu capacitors. (D2X has EMI Shield for this reason. Go figure...)
I also tested a Creative x-fi extremegamer fatality pro with the same results!
So I sold D2X and now I'm with my onboard solution that sucks. (Foxconn Bloodrage - Sonar X-fi)
I decided to go also with an external solution.
I have Superlux HD668B but I'm planning on buying something better for music/movies and just keep superlux for competitive gaming.
I can spent max 180-190€ (241$-255$)
I thought about getting an ASUS Xonar u7 > some amp that you recommend that will drive my next headphones 300 or even 600 ohm
or even skip entirely a sound card from ASUS/Creative and go from my Bloodrage's SPDIF > dac > amp...
The only problem is that I also have a 5.1 set with analogs so maybe the u7 is a must... plus I also need something to put my mic.
The onboard is almost dead so this is not an option.
Thanks a lot!
PS: If I'll go for a solution that does not include a sound card, will I be able to have virtual 5.1 in games with razer surround through spdif?
