DanielMiracle
- Apr 27, 2014
I have been considering purchasing a new sound card or a DAC amp combo, but I'm unsure of which one would suit my needs better for gaming? Does a DAC amp combo provide surround sound?
A (external) DAC/Amp itself can not create headphone surround sound (does not come with an audio processor), you can have something else create the headphone surround sound and then send that thru a (external) DAC/Amp.
The Schiit Modi (optical) DAC ($99) and Schiit Magni headphone amplifier ($99) can be connected to the optical output that might be built into your motherboard's on-board audio.
(motherboards usually come with a built in (low cost) audio processor)
The Creative Labs Sound Blaster Z ($100) can process headphone surround sound (with it's built in SoundCore3D audio processor) and use it's own built in DAC & Head amp.
You can't "run headphone surround" through a DAC, because the DAC creates the sound to begin with from a digital signal that it itself creates from the computer, so unless the DAC has built-in Dolby Headphone, you can't get surround this way AFAIK.
You can send virtual surround sound if you use an external DAC with an optical or coaxial connection and connect it to the sound card. The sound card can then apply DSP to the digital signal before sending it to the external DAC for conversion.
If I were to use the DAC/Amp combo, what would I use to send surround sound through it? & in doing this would I lose any audio quality? See, my issue is that I like to game but also like high quality music. So I would like to get the Dac/Amp for the music, and still run surround sound through it.
Okay, would it work if I were to use the Modi, via an optical connection through my motherboard, and used "Razer Surround" software?
As all modern headphone surround sound is processed in a digital form, all headphone surround sound must be send thru a DAC before the signal can be sent to a headphone amplifier (or basic headphone output).
So does that basically mean it's not possible?
You can always get a low cost sound card like the Asus Xonar DG or DGX for your computer, the Xonar DG/DGX comes with Dolby Headphone surround sound.
Also get the Modi with optical input and the Magni head amp.
You would run an optical cable from the Xonar DG/DGX's optical output to the optical input on the Modi (connect the Modi to the Magni)
The DG/DGX can send Dolby Headphone surround sound thru it's optical output.
Did you have a budget for the audio hardware?
My budget is around $300, and I was considering that. However, I've read that internal sound cards catch lots of noise from the PC. Would this effect the audio quality since it's connected to a DAC? Also, how well would a sound card and a DAC work together?
