Zeroblade
- Jul 7, 2009
Good to know you got your issue solved
Upgrading from say, onboard sound to a DAC is a HUGE step and it's easy to spot the differences immediately. Trying to tell the differences when moving from a good DAC to a better one is much harder though. Listen to your stuff with the uDAC for about a week, then switch back to the EF2's built-in DAC. Usually, it's hard to see and changes or improvements when going up the chain, but you quickly spot the differences when you downgrade equipment, since you're already used to higher-quality sound.
