LamerDeluxe (tm)
Well, I just received my much anticipated D-555 from e-Bay.
Unfortunately, it doesn't seem to be working properly.
The first thing I noticed is that I can hear the electronics through the headphone out, no other Sony PCDP I have has that problem, so that didn't seem to be right.
Secondly, the volume wasn't very loud at all.
Thirdly, there was a really nasty bathchamber type echo in the sound constantly, which could not be turned off in any way by adjusting any of the effect settings.
It had a dent in the lid, I knew that when I bought it, it was said to function perfectly despite that. So I opened it up, couldn't really see anything wrong apart that maybe the large chip inside the lid hadn't been soldered using a lot of solder.
Got rid of the dent, that was nice.
Then I noticed the solder joints of the headphone connector looked a bit black. That's when I found the problem; the resistor directly connected to the headphone-out was burned up, and had come loose at one side as well. I'm not sure if thise would explain all the mentioned problems, but probably the volume and electronic noise, maybe not the echo though.
If anyone could tell me the value of the resistor directly connected to the headphone-out, I could attempt to replace it.
I already contacted the seller about the problem. I'm not sure what to do, the device was said to be working perfectly and I got it for only $60. Maybe I should attempt to fix it and if that doesn't work out return it.
I'm really disappointed, this seems like such an awesome Discman, even with all the problems I can hear that it must sound really great when working properly.
EDIT: The line-out seems to be working correctly. No weird echos or noise. It sounds noticably better than the line-out of my D-25s. But then I tried the Denon DCP-150 and it was in a totally different league, much fuller and more detailed sound.
BTW: Received Sony MDR-565 earbuds with the D-555 and they sound really nice. Slightly less treble and detail than the Philips HE915, but a fuller, smoother and more pleasant sound. With these my Denon seems to sound better than my D-25s.
