Triode User
Member of the Trade: WAVE High Fidelity
I have found the best sound I can achieve from my K50 and Dave/Mscaler combination is to use the USB output from the K50 to a PhoenixUSB and then connect that to an SRC.DX usb to bnc convertor. I then use one of my Storm bnc cables from the SRC.DX to connect to the bnc input on the Mscaler.@Triode User Do you ever go bnc only from your K50 to M-scaler? I know you typically use USB with the Innuos PhoenixUSB. I do the same, but I've been curious about going bnc straight from the K50 because I want to hear what the internal reclocker sounds like. Since you're the bnc cables guy, I thought you might have some insight here. Are there any sound quality improvements or decreases by going bnc vs usb?
I tried using the K50 bnc output but compared to my chain it was not as good. My K50 also has an optical output and I also tried that connected to the Mscaler but I soon changed back to using what I have.
The sound quality difference going from usb to the Mscaler and using bnc in the way I describe is significant to my ears and also to many other Dave/Mscaler owners because they do exactly what I do.
If one is using PGGB files then one can add in a second bnc cable from the SRC.DX and go dual bnc direct to the Dave without the Mscaler.
I do not know why the SRC.DX sounds so much better than the bnc output from the K50 but it is easily heard. In the great scheme of things they do not cost too much so it is worth a try. Have a look at the AudioWise site. Every now and then they run discounts but like I said they are not expensive anyway.
