Syzygies
- Nov 16, 2004
Can a current mirror be used as a very low overhead trickle charger?
This is about as primitive a version as I can draw, that doubles the current through R. There are more sophisticated similar circuits, with more parts and/or higher overhead. This circuit won't have a dead flat charge curve, but we don't need one. With reasonable matching and adjustment, its charge curve should be good enough. The pattern is easily extended to charge multiple banks or increase the current multiplier.
I see a wide audience for Pimeta-class portable amps whose battery pack is recharged from the same stock iPod wall wart that one carries around already.
Unfortunately, a standard LM317 trickle charge circuit has 3-4 volts of overhead, and iPod wall warts put out 13V to 14V unloaded. It takes a bit of cleverness to charge a single 9V battery from one, e.g. a different resistor network, low dropout regulator, Schottky diode.
It takes more that a bit of cleverness to charge 8 NiMH AAA cells, whose charging voltage can reach 12V.
I've long thought that a charging circuit should operate beside the battery somehow, not in series, to get the overhead as low as possible. So I nearly fell out of bed when I reread this section of Art of Electronics last night.
Could this work? Should I experiment with it? If this works, the LM317 circuit starts to look like massive overkill, hunting squirrels with a bazooka.
Do the transistors need some diode protection? (In which case we lose some overhead!)
If this circuit works, then the next thing to explore would be adapting a fast charge circuit to operate beside the battery pack, reducing the voltage overhead by controlling the actual charge current using current mirrors.
Digi-Key carries the Zetex ZDS1009TA, a monolithic current mirror, for $1.25. It doesn't support current doubling like I've drawn above, but it could be used for similar circuits.
