ACE 256
- Apr 27, 2008
Great thread!
I happen to own one of this buggers! I'm running Windows 7 x64 Ultimate. It's a shame this card it's not supported by the kX project, I would like to try the driver, but well...
Anyway, curious thing, when I first installed the card, I didn't have internet so Windows didn't installed it automatically, then I searched a bit and found out that Creative X-Fi Xtreme Audio it's very similar, so I downloaded it's drivers and force windows to install them. Worked perfectly, except it didn't show the jacks information. Later on windows update offered a driver update, and I'm using the "normal" driver now.
I'll mess with it after I mod my card, but I'm not sure how to start.
What opamps and capacitors should I use? I heard at another thread that film capacitors are much better, but I researched for types of capacitors and there are so many!
I'm a PC hardware distributor and have access to dead motherboards which have many kinds of capacitors. =D
What should I look for? Big ass values? Solid ones?
The big green capacitors I see replaced at the pics are all the front green jack uses?
Audio grade caps are your best bet. I recommend Nichicon's muse series or if you have the money Rubycon Blackgates. I would stay away from large capasitance and go for quality.
hey to what you changed those stock buffer caps for the opamps 22uF? I'm thinking about to upgrade my audigy platinum too. thanks
I used 220uF Nichicon Muse caps for the opamp buffers and decoupling caps.
Sorry for the delay, I was moving and I just now got internet back.
