Leny
- Mar 1, 2008
Hello dBs,
Yup, you have confused yourself a tad there. It will be either CCS on top of a amplifier tube, or mu-follower whereby the upper tube (or FET) approximates a CCS. Never a CCS on top of a mu-follower for the reason that you noted.
If you choose the CCS on top of an amplifier tube then the PSRR is very high. The current from the CCS is divided between load and tube, hence the current through the tube is not constant. The output impedance is dictated by Rp (the internal anode resistance of the tube).
If you choose mu-follower then the PSRR is less high, and the performance of the PSU is more important. The mu-follower diverts PSU current to the load while maintaining almost constant current through the lower tube. The output impedance is dictated by the follower section, which if done right is going to be significantly smaller than the internal anode resistance of the amplifying tube.
Both CCS loaded amp tube and mu-follower are fine for parallel-feed configuration. Surely the output cap value is determined by the inductance of the output transformer primary?
Cheers for now,
L.
Cheers for now,
L.
