Sebastiaan156
Dear all,
Since a little I notice I dislike all hybrid iem's I own. Things like the Ikko OH1, trn V90 and CCA C10.
Not that they are all bad, love them in some sorts of music.
In some music the voices are really nicely seperated from the music/bass and I love this feature of the hybrids. In music from Joan Baes they are really nice. Or I see fire from Ed Sheeran they also shine.
But I have the feeling dynamic drivers have a different speed from ba drivers. In complicated music/ full of different frequency music they tend to sound really bad to my ears. Think of Wish I had an angel from Nightwish. They mess it up big time sounding off. I have the idea this is because some sounds are being devided between the dd and the ba drivers and they have different speed and decay which rips the music out of Ballance and sounds off.
Not sure if this is the reason but all my single driver style iem's don't have this issieu. T2 only dd is fine, bl-03 only dd is fine'ish, p2 only planar is fine, m300 only is fine but all my hybrids fail hard!
Full size dd or planar are also ok'is noted planar works better than dd for this use case.
Have any of you experienced the same issieu or have an explanation for this?
I use flac files played from PC with a creative ZxR dac amp card and pdv2 and flac files played from phone with a 9038s and dc01. All sources show the same problem.
Is it just a ba problem or a multiple driver problem or as I suspect a hybrid problem?
