wquiles
- Dec 8, 2007
Newbe here - trying to learn more
For reference, I have an 7-8 year Sen-580's which sound to me about perfect, specially once I build my own desk and portable amps for it. However, size-wise we all know the Sen's are not really "portable".
My first "really" good earphones were the UE 5 pro's. Really great sound, balanced, natural, but the fit was not the best after an hour or more, and since I was itching for an upgrade, looking for even better sound (my 580's are great to my ears and are therefore my basis), I recently ordered the Shure SE530's given that they have so many great ratings not only for fit, but also for sound quality - the best "universal fit" in several web sites.
So I get the SE530's, and after a week or daily (after work) A-B-A-B comparisons, I am disapointed in the SE530's. Yes, fit wise they are great, a definite improvement over the UE, but after all of the reviews I was (naively?) expecting the Shures to sound even better. At least to me they did not. Don't get me wrong, they are not "crap" or bad, but the mid/higher freq. were "soft" or attenuated. I have read that some reviewers of the SE530 commented on the "different" higher freq. performance, but at least to my ears something is not quite "right".
I tried both MP3's and Flac files from my PC, and 192/320K MP3's from my Ipod - pretty much the same results. Christina Aguilera, Kelly Clarkson, and Celine Dion did not sound "normal" to me. If I go back to the 580's or the UE 5 pro's, they sound normal again. Is this weird? Uncommon?
I decided to order the UE Triple 10's for a last ditch to my "upgrade" dreams, and they should arrive late this week, so this weekend I will be able to do the "final" comparison to see what I will keep and what I will return/sell.
I am getting great bass and solid seal with the Comply/foam tips, so it is not fit from one model to the other. It is not the slightly louder volume of the UE over the SE530 either, and the source material is the same while doing the A-B tests. Any advice you can give me, or should I simply continue trusting my ears and my gut feeling as to what sounds "right"?
Thanks in advance
Will
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Thanks in advance
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
Will
