syndrome
- Oct 23, 2005
MP3Tag is really good for fixing tag problems that other apps (like mediamonkey) creates
Originally Posted by Luca T /img/forum/go_quote.gif I used Mp3tag as program to edit the files and the tag should be id3 v2.3, I will check everything again to be sure! PS: the same problem like twin album appears even if I sort by artist (I mean it shows twice the same artist and it splits the songs some in one and some in the other)! EDIT: I checked songs with mp3tag and as I told you songs were already in id3 v2.3 then just to try I used mp3tag again and I selected the songs and just saved again (without modify anything I've just clicked "save") and now it works normally! It's quite strange! Anyway thanks a lot! |
