olsonc84
Aka: craigjolson, spierce, audiophoholic, SunnyMcGrath
- Dec 22, 2010
Been trying to use MediaMonkey (not Gold) to create playlists to send to Cowon S9 and the songs aren't showing up.
They are in the MediaMonkey playlist and I tried both syncing that playlist and sending it directly to Cowon device. When I power on the S9 the playlist is there, but no songs are in it.
Conversely, when I try creating the Playlist in JetAudio and dragging it to the Playlist folder on the Cowon, it doesn't show the playlist but the songs are sync'd.
Any help? Is there a better program to use than MediaMonkey?
