renugaid
- Jun 1, 2008
Hi I bought a D2 recently from the US and it came fully charged. Its now half way through its first battery usage and I'm wondering if I need a voltage converter as well or if I just need an outlet converter that will allow me to plug its AC adapter into an Australian outlet. The voltages between the US and AU are a bit different so I'm just wondering if that would make a difference. I also have a pico with the same question about voltage conversion. Is it required? Or can I simply charge them on an Australian powerpoint without having to worry about overvoltage?
thanks for any help
renugaid
thanks for any help
renugaid
