TijmenK
- Sep 19, 2012
My Fischer Audio DBA-02 mkII died again a while back, the right side is just fine but the left isn't doing anything. I had my first pair replaced under warranty with the same problem but the second pair died just a couple weeks out of warranty. At first they were willing to fix it, but now they're not replying to my e-mails anymore. I'm not too fussed because I lost most of my confidence in their quality and service a while back anyway, and apart from sounding great I didn't like them that much.
So now I have a pair of broken IEMs that won't fix themselves gathering dust, I figured I could have a crack at it myself. I don't have any experience with any of this, so it's mostly a research mission without any hopes of actually fixing anything. My logic is that they're all passive components without too much risk of breaking, leaving a connection of some sorts to be the culprit. The plan is opening them up, having a good look at anything and, unless I see a clear problem, recabling them with cat5 cable and see if that fixes it.
Now I didn't start this thread to just document my heroic efforts, it's because I know nothing about any of this. I have two questions at the moment:
1. What would be the best way to open them up? Blast them with a hair-dryer and see if that will melt the glue? Attack them with a scalpel to the seam?
2. What should I be looking for once I'm inside? Will it be obvious something is broken? Can I test something with a multi-meter?
Thanks in advance!
Thanks in advance!
