jdimitri
- Aug 21, 2005
Hey all, just want to share my first impression with the Move
I bought the move as a downgrade(ish) from my tomahawk, because i need all the money i can get to buy a raptor (on its way
First impressions:
Using AKG K501- around the same level of performance, and this is from the first listen only.. No burn in done yet whatsoever
K701- Sounds pretty good, drives it decently.. but seems like it needs a bit more oomph. Never tried the k701 with my tomahawk so can't compare it
ES2- Noooooo
Unfortunately the RSA-ES2 bond was real.. and the move combo sounds noticably worse than the tomahawk combo (from memory). It seemed a lot harsher, but hopefully it'll soften up as some burn in hours sinks in..
Build/Looks:
Build is excellent.. very solid, easy access to the battery compartment (with a spare plastic thingy that closes it, just in case). Would've been nice if the current/gain switch are externally accessible though
For now, i have to say i prefer the look of the black tomahawk.. but i guess it's a personal choice
BUT tomahawk has those 2 screws on the back which WILL scratch your mp3 player or whatever you have attached to it if you're not careful
I'll update this thread once i've burnt it in and tried the DAC etc
Ps.. some of the things i wrote may seem harsh.. but this is compared to the tomahawk and so far it does almost nothing worse (except for the synergy with ES2) at about $70 less
I guess i might miss tomahawk's tiny size (not likely.. never carried amps in my pocket) or the ultra long battery life, but let's see..
First impressions:
ES2- Noooooo
Build/Looks:
