kelly
Herr Babelfish der Übersetzer, he wore a whipped-cream-covered tutu for this title.
- Jan 1, 2002
tone,
Very high end tube amps can do amazing things. Nick said something to me today to the effect of, "The differences between solid state and tube amplification decrease as you spend more money on them" and I believe that to be generally true--good tube amps borrow some strengths of solid states and good solid states borrow some strengths of tube amps.
Melos Vs RKV (without AB, by memory only)
RKV - Incredible lower mids and bass, slightly elevated noise floor
Melos - sweeter upper mids and highs, lower noise floor
The Melos is a hybrid amp and will drive a greater variety of headphones more easily. The RKV excels at high impedance headphones.
The missing bass of the 831 may not be apparent to you on the MG Head because the MG Head is missing bass too.
On a different amp, an AB comparrison with the HD600 or DT931 or Etymotic will clearly demonstrate to you what is missing. The 831 is a good headphone though, if you do require a closed headphone.
