fiddler
- Jun 24, 2001
Okay, no nut in that case.
Well after some more listening, I've found that the level of detail in the Corda, if you can believe it, is even greater than before the mod. Also, the attack seem to be much quicker. The result: saxophones sound more saxophony, violins sound more violiny, pianos sound more pianoey.. pianoish.. whatever..
I find that the beginning of the note (the attack) really defines what a given instrument sounds like, and the modded Corda makes these attacks even clearer. Pianos and percussion sound much more articulate and now you can really hear the friction between the strings and the hair on bowed stringed instruments. I was listening to Brubeck's Take Five and I noticed much more "breathy-ness" in the sax at the beginning. The sound really seemed to come alive, giving each instrument more character. But despite all this added detail, it never sounds harsh or coarse, although it's definitely NOT what I would call smooth.
So, what kind of improments could I expect by swapping out the opamps? I'm dying to hear it.
NOTE: I haven't done any direct comparisons between the stock and modded Corda. However, I made the above comments after listening to familiar music that I've been listening to on my stock Corda + HD600 combo for about 6 months, so I have a good idea of what the Corda used to sound like.
NOTE #2: The above mod cost me virtually nothing, except for some solder, a bit of desoldering wick, a couple hex keys (METRIC ONES! I stripped a couple of the screws on the back plate using an imperial one... damn you Americans and your inches), and a bit of time. If you have a Corda and a soldering iron, this easy and almost-free mod is a must!
