nspindel
- Oct 12, 2005
What I do is set my file library up in the following format:
\genre\artist\album\## - songtitle.flac
If you store your music this way, you can use software like Abander Tag Control to extract the tags from the file structure and save them into the flac files. So yes, there are programs to do this for you, ATC is my recommendation, it worked much better for me than Tag & Rename, as others have mentioned was troublesome with flac.
Originally Posted by uofmtiger /img/forum/go_quote.gif Can anyone answer this? I used Foobar and now I just need some tags that may or may not have been missing from my WMA lossless files. Foobar worked fine for me. It did say it would take nearly 7 days to convert all my files, but I decided to do smaller batches and it worked while I was away from the house. |
