jdkJake
- Mar 16, 2009
Okay, one last set of measures (even I think I am starting to beat a dead horse!):
This time I changed the measurement methodology to probably the most realistic setup yet. Not sure why I did not do this from the start, but, the SoundBlaster has a headphone out jack (with analog attenuation). So, I routed the headphone out (through the device under test where appropriate) to the mic input for all tests. There is no digital attenuation on the signal (all outputs full) and the mic set at 50% (0db). When performing the loopback, the analog attenuation is heavily applied. When using the transformers, there is no analog attenuation (wide open). Input levels for all tests are about -3.6db at the mic.
So, lets see what we get:
Freq:
THD:
IMD:
Dynamic Range:
Noise:
This particular set shows more similarities than differences, so, you can draw your own conclusions. Mine lean towards stating the transformers are allowing more signal through (less attenuation) and adding little to no distortion or frequency artifacts. At least that is what this set of measures show, which, I have certainly learned can be all over the map across differing samples and totally open to interpretation. Pretty much like any other statistical characterization.
So, at the end of the day, I am not sure if I have helped or hindered the argument, but, there it is.
Consider this horse dead.
Freq:
THD:
IMD:
Dynamic Range:
Noise:
