Dexter M
- Dec 16, 2012
Logitech Z523 (Speakers) Manual: http://www.logitech.com/repository/1411/pdf/27264.1.0.pdf
Summary of speakers: Has a subwoofer which connects to the wall for power, 2.1 system.
Jack Adapter I just ordered: http://www.amazon.com/Monoprice-Plated-6-35mm-4-inch-Adaptor/dp/B000KI0YXU/ref=sr_1_5?ie=UTF8&qid=1357203677&sr=8-5&keywords=3.5mm+Stereo+Jack+To+1%2F4
Summary of adapter: 1/4-inch (6.35mm) to 3.5mm adapter. In other words, 3.5mm is female and 1/4 inch plug is male.
All I know right now is that I can connect a 3.5mm cable using the adapter to my speakers. I just don't know if it'll work.
