Ghoostknight
ah, got itThen again not many people mount their DAC inside the computer chassis
is this a dedicated streamer you are building? or just your "normal pc" you try to integrate the dac into?
either way, i would probably use this then: https://www.ebay.de/itm/195508967625 and a cable of your choice, the pcb layout is probably straightforward and best case impedance matched but even if not the short pcb traces shouldnt have much influence and from there you can go with a good usb cable of your choice
but you can also try the cable you already ordered first
i would probably avoid it, since a straight cable is all you need in this caseAnother option while not as "clean" is this adapter cable with a small pcb at either end. This particular adapter from China also has discrete components soldered to it which are there for a purpose, but they give no technical information what it does. It looks a bit hoaky but that is all I can go on as I'm not an expert here.
