bmwpowere36m3
- Aug 17, 2008
I know this is not the typical question for these forums, however the basic circuitry must be similar to that of an op-amp. I've decided to add an external mic to my camcorder (Aiptek A-HD+), since the on-board one is terrible.
I need a mic that can operate in high noise environments and not "clip" and "pop" as the onboard (overly-sensitive) does. From what I understand just using a simple condenser mic with an amplification stage, running on a 9V battery.
I've bought a relatively cheap condenser mic at radioshack:
CB/PA/Mic Condenser Microphone Element (270-092C)
Supply Voltage: 1.5 - 10VDC
Current Drain: 0.5mA (max)
Signal/Noise: 40dB (min)
Sensitivity: -65dB
Output Impedance: 1k
I've seen a circuit like this:
ANy help would be great.
Sensitivity: -65dB
