zotjen
- May 28, 2002
This morning when I turned on my PC, it wouldn't power up. After making sure everything was connected properly, I noticed that the LED on the back of my PC was flashing. This lead me to believe it could be a power supply issue. Using my company issued laptop (which I'm using as I type this) I found some websites for troubleshooting the problem.
After trying various things to determine the cause, when I unplugged the power supply from the motherboard and then plugged the PC back into the power outlet, the LED was steady which indicated the power supply was fine. The problem then has to be with either something plugged into the motherboard or the motherboard itself.
I then tried unplugging everything from the motherboard one by one but still have the problem. I haven't removed the CPU yet but I figure if that is the problem, I'll need a new PC anyway. The only other things I haven't unplugged are the power cables that plug into my drives (hard drive, DVD, etc.). For some reason I am unable to remove the cables from the drives themselves. They just won't budge. Since these cables are bundled to the main power connection on the motherboard, I'm thinking its possible that one of the drives could be causing the issue but I can't figure out why it's so difficult to unplug them.
Is there an easy way to confirm that the motherboard itself is the problem? Since my PC is 5 years old, finding a replacement may be a hassle. My PC is also and HP and I heard they "tattoo" the motherboards so it's not that easy to just stick a new one in.
