gregorio
- Feb 14, 2008
However it is usefull in the studio for the purpose I mentioned as everyone knows mistakes do happen & the ability to recover from them is priceless & floating point does offer that to a degree that 24 bit integer doesn't.
I'm not really sure how saving a 32bit float float file allows the ability to recover from a mistake more than with a fixed point system does? The only potential benefit of a 32bit system is that it is more forgiving when it comes to gain staging a large number of tracks. Don't forget, most commercial studios use fixed point recording systems.
Agreed that most of it is noise but there is musical cues that can be recovered out of the noise as humans can hear into the noise by as much as 20db which is why dither was developed. It was developed in order to encode sound below the theretical noise floor of CD but does add noise to make this possible.
Not really, TDPF dither was developed to randomise quantisation error which could otherwise be correlated to the program material potentially creating unwanted tones.
Without dither Digital goes deaf below -90db
Which is true for a 16bit master but still of no consequence when the noise floor of a master is going to be at least 30dB above the digital noise floor. Word length reduction to 16bit from 24bit using a noise-shaped dither would provide a dynamic range of roughly 120dB in the critical hearing band (at least 60dB below the master's noise floor).
By the way some mixer programs offer 64 bit floating point even at the semi pro level.
Agreed that all this really means nothing to a song that is compressed & limited to the hilt with some Ive seen with seemingle less than 10db dynamic range. I was outragiously appalled at the DVD audio release of Rush's Snakes & Arrows DVD-A disk as it was squashed all to hell in a hand basket so to speak It seemed like less than 10db dynamics though I may be exagerating to a very very slight degree. much to thier credit though it seems they did it without creating massive clipping type distortion unlike many such releases. Even so to me it is worthless to release such music on a high resolution format then not make use of any of it. Rush has a past of releasing very high grade music with resonably high dynamics for the genre music the play so this was a huge huge disapointment
64bit float (or 48bit fixed) does potentially provide some benefits in a mixing environment. It provides a windowed system allowing for gain reduction of tracks of up to -90dBFS without loosing any resolution and also does away with any possibility of the summing of multiple processing rounding or truncation errors causing audible artefacts.
I agree though, the ridiculous loudness wars seems completely at odds with the consumer demand for greater bit depths. It's like wanting cars with 10,000 horse power while at the same time reducing the speed limit to 5mph.
G
