Cheebamaster
- Feb 6, 2013
So I've been doing a bit of research and am looking for the best sound possible that I can get out of my computer. I currently own a set of Denon ah-D2000 and am thinking of either getting the Sennheiser 650's or 700's. I also have an internal sound card but feel that this isn't adequate enough for producing the best quality sound.
I am thinking of buying:
http://www.amazon.com/Sennheiser-HD-700-Headphone-Black/dp/B0070U8KSM/ref=sr_1_11?s=aht&srs=2530385011&ie=UTF8&qid=1360177460&sr=1-11&keywords=sennheiser
For headphones (or the 650s) ...reccomendations??
AND
either: http://www.amazon.com/Unsurpassed-Performance-Converter-Headphone-Amplifier/dp/B00ADX98AM/ref=sr_1_5?s=electronics&ie=UTF8&qid=1360176577&sr=1-5&keywords=headphone+amp
OR
http://www.amazon.com/NuForce-Icon-Performance-Headphone-amplifier/dp/B00370OIYE/ref=pd_sim_sbs_e_2
What is the difference?
Is this all I need? Are there any extra cables I should be getting or will this take care of it. Also, is this completely overkill for listening to radio/itunes music? I'm not looking to waste money but definitely want a very quality sound setup.
Thanks in advance!
AND
OR
Thanks in advance!
