Ghoostknight
after testing alot it just sounds more "muddy" to me and you lose the real character of a specific songThat isn't ideal because mixes are designed to use room reflections to fill out the body of the sound and give it life.
more detailed for sure, well "dead sounding" might depend on the linstener and how used you are to it, imo a good treated systems sounds way better and from listening i also imagine its closer to what the sound engineer intendedWithout that, sound may be more detailed, but dead sounding.
for me it will be always "treat as much as possible" with it being still a somewhat enjoyable room (thats why i like to use furniture), there is not "really" too much (casual, so no room in room and that extreme stuff..) treating, just too little
closed headphones give me anxienty, i much prefer open back onesIf you want that kind of sound, closed headphones are better because they put the sound in an acoustic vacuum.
tho i imagine in terms of reflection it doesnt matter much if open or closed... closed back just isolate more background noise which isnt really the same
well, i would like to try someday a good tuned large room but so far i just heared crappy setups without treatingEven though it can be a lot of work to optimize a room for a speaker installation, the rewards are huge. You have physical sound inhabiting a real space. You feel the bass in your chest, the air vibrates around you, and the music inhabits the same room you're sitting in and interacts with it.
discos are not comparable with a flat system in a treated room tho, they always sound like they boost bass by 10-20db
these are also the most improtant, tho it doesnt mean directly harmonics above that "dont matter at all" the difference is just too little to not worry that much about itSound engineers usually worry about three levels of harmonics.
