- Aug 2, 2008
Thanks for that link (my HF reading is limited toward my subscriptions and links of interest provided to me by friends). I think it's pretty cool you guys did a blind test.
The other site's KGSSHV thread won't show up in google.
You'll have to go there and trawl through the thread for the info...
Kind of pointless to state specs about KGSSHV. Every build varies.
Unless MH here has actually run tests on his KGSSHV everything is moot.
I don't think we will ever see independent measurements of the HV version of the SRM 717. For now one can only can extrapolate from Stax measurements since the KGSS is a copy of Stax's SRM 717 design.
Alternatively as Gurubhai pointed out Dr.Cavalli and Craig have real world measurements in place.
Seriously...this thread is devolving big time. I see that many are out in full force to support their "team".
Or because they'd rather not.Stax only at 100Vrms, but the Electra is specified at 300Vrms as well. Why not run the full gambit and stop at 300Vrms?![]()
The KGSSHV numbers are out there...you just have to look.
Peter, I haven't heard the KGSS and the KGSSHV, but I'm sure they are fantastic amps. I heard the BHSE with the 009 and while I felt it sounded very good, I liked the LLMK1 + 009 pairing better. There is no "team" here. I'm not with the "Stax" mafia, or the "Cavalli" surenos gang, or the "Craig" bloods. I just disagree with the assessment that the LLMK1 + 009 sucks.
So far I've seen a (removed) review by Spritzer saying that the LLMK1 rolls off at 80 Hz, and pretty much colors horribly the whole frequency spectrum. That is NOT my experience at all.
Then someone (not me) brings up ACTUAL measurements (NOT SPICE SIMULATION results). I say I agree, and ask for measurements on the KGSSHV, and all I get is ... they are "there". I searched "there" and have not seen even a THD number, let alone FR plots, THD+N plots under different conditions, IMD... You said you'd like to see this before putting down your hard earned money... Well?
Yeah sad to see ppl come and defend cavalli when u just posted impressions after owning both.
No supporting any team here. Just trying to help the objectivist in you that you mentioned earlier in getting the whole picture. After all you brought up the lack of measurements when they were all there in plain sight on the manufacturer's website for anyone to see.
Yes the measurements on the LLmk2 is independently verified. You can contact the company that measured it to do your due diligence.
And if the measurements are avialable on another site as an image, am sure you can upload it here. Don't think HF frowns upon that. I would still believe independent measured specs over simulated specs from the 'designer'.
And since this is a thread about impressions here's mine.
Have consistently found a majority of amplifiers 'designed' by the same person that 'designed' your favored stat amp quite bland, flat and boring. This includes the Dynalo, the GS1, Gilmore lite, GS-X (not the mk2 version). And I have found that other folks who agree with my ears feel exactly the same way.
Not that i have bad ears or you have bad ears. Its just what works for you. THere are plenty who will fall in either camp.
COming to electrostats, I haven't heard DIy version of the SRM 717 or its HV version.
But I have heard the BHSE which is basically inspired by the Stax T2...the BHSE is not new circuitry nor involves Bob WIldar like analog wizardry. Thanks to STAX it started out its genesis from a good solid design.
BHSE great with 007 to me. Easily an end game rig.
BHSE with 009 NOT a good combo to me.
Electra does equal justice. An excellent amp.
LLmk1 Fantastic with 009. Good with the 007.
LLmk2, does equal justice to both headphones and on par with electra in pleasing my cochlear but different sounding.
Funny I haven't heard the BHSE yet, but the LLMK1 + 009 pairing was only marginally better than the SRM727II and quite a bit behind the KGSS and KGSSHV. FWIW, I happen to agree with spritzer's comments of the lack of any real sub-bass with the LLMK1 (as I posted on my review)...and I tried for almost a month to see what I could do to change my mind over that and the overall sound I was hearing, but to no avail.
And I've posted the KGSSHV comments above FYI and I'm not sure you understand the differences between the DIY business model (there isn't one as its all open source) vs. sellers who look to make a buck. But as Marv pointed out, measuring stat amps isn't so easy I suppose. But hard doesn't = impossible and I'd encourage more of this IMO. Simulation results too are also welcome if that's what's on hand. You'd be surprised how accurate they can be.![]()
