imackler
- Nov 17, 2008
I'm guessing that a_recording will find the SE846 incredibly overprice when compared to cheaper, universal dynamics!
What is the difference between BA and Microdriver?
ATH-IM04
Series top model equipped with a newly developed BA driver a total of four low-pass × 2, mid-range for × 1, in the high range for × 1. I pursue the exact response by the quad-dedicated network design. Cable is detachable, that it has both the maintenance and reliable connection. It should be noted that the pin in the pin 2, the shape is different from previous sale model and "ATH-CK100PRO". And a wire inside the cable, you can put it on over the ear.
Play frequency band 15Hz ~ 20kHz, output sound pressure level of 101dB/mW, maximum input 3mW, impedance is 14Ω. Stereo mini plug / L type.The Y cable type, length 1.2m. Weight with the exception of the cable is about 8g. In addition to silicon (S / M / L size), earpiece bundled configuration ply form earpiece also (M size). Case is also included.
Meanwhile, the floor is open for upstars [sic] like Vsonic and HiFiMan to undercut these entrenched manufacturers. Because really, they have no history of pricing, no roadmaps, they don't have vested interests enshrined into monolithic structures of middle management, shareholders etc etc.
