tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
FLAC compresses white space, not anything with data. Print a page out on a printer and look how much white space is there compared to the text - even a full page of text. The analogy is valid.
There is at least one major hole in your analogy. There are no white spaces in a music file.. It is all 0 or 1.
To get an idea of where errors are bound to crop up in FLAC: a 16 bit WAV file has quite a few compromises in it after conversion from 24 bit (as used at the studio end for editing etc.) Indeterminate boundary bits consisting of alternative 0s and 1s in a WAV file are easily interpreted as a string of just 1s or 0s after conversion to FLAC. Much is made of the FLAC checksum before and after compression. But in reality, it should be the WAV file checksum that should be compared against the compressed FLAC checksum. If those two match, you can then have a better certainty that no bits were lost during the making of that FLAC file.
No, a digital file has 0's or 1's - but you don't know what it is until those 0's and 1's are converted. It might not even be music or even audio, period.
As for music, it has dead space all around. If the music was totally compressed with all frequencies having an amplitude not equal to zero, that's the only way it wouldn't have white space. The digital sampling is setup for 20-20KHz. Every frequency per time that's not producing sound is white space.
