ninioquiroz
- Nov 9, 2011
Hi
I've mostly been a lurker for a few months, and first I'd like to say this is an awesome community. I want my main configuration to be MacBook Pro > USB DAC > Headphone Amp > D1100/HD598/HE-3? HE-4?
I currently use a really cheap mini amplifier plugged via RCA to a Samsung Blu-Ray player to listen to my CD's. Simple and economic as it may be, I at least get much better music quality from it compared to my iPhone/EQu set, which is my main source for most of the day.
First, I'd like some opinions on which USB DAC to choose. Right now I'm considering the Music Hall 15.2 as my closest choice, since it comes from a good brand, complies with my limited budget of no more than $400 dollars, according to the specs it has a decent Texas Instruments chipset and offers 24/96 processing trough USB and 24/192 on Optical.
Any suggestions on a different DAC and which amp to plug it into? I think I'll go for the Schiit Asgard next, since it has very good reviews as a decent-priced class A amplifier.
Second, at risk of passing off as a mere newb, I have to ask: How does the optical out on my Blu-Ray player work? My doubt is on whether the signal will be bypassed and 'pure' from the player to an external converter such as the 15.2 or will it be processed on it's internal DAC by deafault. I know, obviously, that the signal I get from the RCA out of said Blu-Ray is already processed going to my mini amplifier, the thing is, I'm not quite shure what happens when using the optical audio out.
So, what do you think about my potential Music Hall 15.2 > Schiit Asgard setup? Any suggestions?
Thank you
Thank you
