andrew3199
- Mar 8, 2003
yes! I think this is the way to go, although finding a good walwart may be a problem. Elpac did make a very nice one, now discontinued. It's a pity the Mini[size=xx-small]3[/size] wont run off a 24 volt power supply I have a spare "Firestone Supplier" that needs a job.
Originally Posted by pdupiano /img/forum/go_quote.gif I'd vote for the mini3 and use a dedicated psu rather than the battery. As far as I'm concerned, the Mini3's one of the most powerful "portable" amps I've listened to. The reason why it's "Portable" is that I rarely used it for portability, I wound up using it at a desktop amp at my lab. The SR71A is probably the only one that could drive the hd650's using actual portable power supplies (Batteries not wallwarts). On a side note you could try other DIY amps that use 2 9v batteries, add an opamp socket and you're in business. |
