so this cmoy is to be used after my e-mu 0404's lineout (which i assume as no DC offset, but i probably should measure it) until it is replaced my hopefully a soha II. Also it will be used after my sansa clip's Headphone-Out (.5 mV on left channel with nothing playing). Gain will likely be 1 or 2
with my first cmoy, I used 1uF metal film caps from ratshack. I'm not quite sure if I would have been able to fit it in a altoid tin. after measuring the dc offset, well, why not forgo the caps?
With removing the caps, Is there a point to the R2 that was used to create the highpass filter? Will this just be sucking current for no reason? Can I remove it?
As for the potentiometer, I was again going to get this stereo log taper 100K pot (the only stereo one) at ratshack. However, I was debating the quality of this pot and the noise it may add. For this reason, I was considering forgoing the pot and just using the 0404's pot on the lineout that goes from -infinity to +0. With a gain of 1 on my old cmoy, it played plenty loud for my dt880's.
However, when pairing it with the clip, which is a better tradeoff? ratshack's pot or digital volume control? I could also leave the pot in and use it minimally.
Next, the power supply. I managed to find 1000uF electrolyte caps I could fit on my board, surprisingly. So with all that current stored up, I was trying to think of how to make the virtual ground a little better without an IC. although they would pair very well with the TLE 2426 with all that juice, i dont know if i want to throw a whole IC on there with space restrictions (I am going to use 2 9V batteries). So I'm looking at the resistor dividers. With the current stored up, can I get away with throwing larger resistors than the 4.7K and not have so much uneven virtual ground splits? Or are these caps not a factor at all, its simply based on the current across the resistors that divide it (i probably need to re-read that section). And is it not even a problem with 18V's of headroom? The section only mentions that resistor dividers/unbalanced ground affects the battery life, but I have heard others say it effects the SQ, is it true? i don't care too much about battery life, should i just throw in low value resistors?
lastly, opamps. I don't want to go through the hassle of 2 single channel opamps, so I need a dual channel on a single IC. I know a lot of the HQ ones are single channel. I would like to know what the top ones are without TOO much work to get them stable. I don't mind adding in a cap between the rails or anywhere else or some other discrete components, just more no IC's. What I'm looking at:
NJM 4556
AD8066
AD823
AD8620
ad8610
TLE2142
TLE2082
LM6172
AD8397
OPA2107
LM6172
ne5532
TLE2072
OPA2111
not sure if these work in a cmoy?
AD797BRZ, AD8022, AD8021, LME49720, AD8599
opinions on those or any other options? looking at 1 or 2 gain, 18V supply, will not have output buffer. Does max output current really matter if I use high impedance moderate sensitivity phones?
in other news, i am so far behind on amp building but i finally graduated and am looking for a job. and in the mean time i will build some amps. i ordered a couple things 1 year ago that never got built, and now i want to build something else.. like that soha II everyone's been raving about.
NJM 4556
AD8066
AD823
AD8620
ad8610
TLE2142
TLE2082
LM6172
AD8397
OPA2107
LM6172
ne5532
TLE2072
OPA2111
